Allows you to add a remote MEP with the given MEP ID and MAC address to an existing association.
| domain_name | Enter the domain associated with the MA you are configuring. |
| association_name | IEEE 802.1ag or ITU-T Y.1731 association name. |
| mepid | Enter the MEP ID of the remote MEP being added. The range is 1 to 8191. |
| mac_address | Specifies the MAC address for the remote MEP being added. |
N/A.
Use this command to add a remote MEP with given MEP ID and MAC address to an existing association. Use the show cfm detail command to verify your configuration.
